Duraspark connector - 3 pin
Does anyone know of a source for the three pin female Ford connector, used on the distributor, ignition box, and for the engine to body harness connection of 80's Fords? I can get the male end, NAPA has them, Standard makes one, etc.. That's the one that usually holds up fine, the one that crumbles is the hollow shroud with the three pins inside, and no one seems to supply that one.
It's the opposite of Standard # S-698 (plugs into it). I can just splice it with anything, but would prefer to use the pigtail if I can find one.
Thanks.
Thanks.
