Upgrade EFI or Convert to Carb on 351W
Hey guys, i have a pretty nice built 351W with stock EFI and im pretty sure it's limiting the power i have because the EFI is not enough for my engine or if the spark is not enough since i can sometimes smell very rich fumes. It runs good on high RPM's but on idle it will want to die down. I dont know if it's a spark issue or if it's a wiring issue or what it actually may be.
All i know is that i have a pretty good set up and i dont know whether to match what i have in the engine with a good aftermarket EFI or just do away with all the electronic stuff and go to a carburetor. Any ideas? comments? suggestions?
This is what i have now:
1993 F-150 Flareside
351W
over 30
wiseco pistons, forged/flat
stock heads, ported, polished (compression ratio, i wana say is 10.8:1)
i believe valves and springs came from 5.0HO
trick flow pushrods
stock connecting rods
stock lifters - no aftermarket roller rockers
pioneer race balancer
high volume oil pump
stock water pump
cam is custom (dont know specs) but it sure makes a difference.
headers
flowmasters
K&N intake
tansmission
removed E4OD and installed C6 - overhauled locally - put in about $1000 into it....not exactly sure whats inside, but it does shift very nicely
373 gears on 33-12-15 BFG's
BW1356 transfer case
it may not seem like much but it sure runs like heck...and when it's on 4L going up the sand dunes, man, hang on to your undies!!!
like i said, any ideas or suggestions or comments are appreciated!
351W
over 30
trick flow pushrods
stock water pump
headers
flowmasters
K&N intake
tansmission
i still have stock injectors..not to mention wiring is stripped bare at certain parts of it...vacuum lines are cracked, broken or missing...it runs ok but i know it needs improvement. what i dont want to do is invest thousands when i wont be using it as much. i want good parts but i dont want to pay 3 or 4k for an EFI system. im looking to spending maybe at the most $1000.
im fairly new to this mechanical stuff......i know just enough to get by.....im totally lost with this EFI stuff.
can i get a MAF system from a different vehicle and use it and expect better performance???
and.....i dont feel comfortable doing this stuff myself..i'd probably pay someone to do it......
I'm not sure I understand what you mean by the entire EFI system...The computer uses sensors to gather infomation about the engine and how it is running. The sensors are part of that system, as are the solenoids, etc. There is a replacement computer you can use by having a custom tune, but as far as replacing the sensors and vacuum lines, I do not know of a kit...I don't know how there would be a higher performance vacuum line, but rubber\silicon lines are far more reliable. www.rjmtechnologies.com has a harness to convert your current harness to MAF and I hear that makes the swap much more simple.
Yea, you're right thats the very wrong website, lol my bad.
http://www.rjminjectiontech.com/
The sensors are needed for the computer to do it's job, and as far as better wiring, stock is fine, the only thing to really consider is corrosion and signal loss, which stock handles both fine. The solenoids are for the emissions system, which actually makes the engine run better. Injectors depend on the set up you have, but if you run anything other than stock you'll need a custom tune.
sounds good..i'll look into it and see what i can come up with...thanks...i'll prob be back on this post and see if anyone else has joined in the conversation....i also just started another thread on my transfer case motor....check it out, maybe you can give your input on that one as well...thanks again....
