need electric fan advice
i am going to be installing an electric fan setup in my 94 f150 since it tends to overheat pulling my 7500 lb camper. i need some advice on what to get and what to look for. i think i am going to get a dual 16" setup from jegs pulling 4200 cfm.
does anyone know what the stock fan cfm rating is?
any advice is greatly appreciated
An electric fan does not have the cooling capacity of the OEM mechanical/clutch fan. Either the radiator has mineral build up, or the clutch
on the mechanical fan is defective.
And, as Adrain has said, the failure rate for e-fan setups is much higher than OEM mechanical/clutch fans.
