93' F150 oil pressure dropped fast
Don't know much about engines, so bear with me...
So today I was driving about 70mph down the interstate and I noticed my oil pressure dropped, all the way past the L, I pulled into a gas station and checked the oil, it was fine, but my engine was making a "knocking" sound. I drove home and whenever I eased off the accelerator the oil pressure would go back up. I let the engine rest for a few hours and started it up again, and the knocking was gone and oil pressure was back to normal. The engine is a 5.0L and has 118k miles on it, the rear main seal needs to be replaced but that's the only other problem I noticed with it. I am going to get it looked at but my mechanic is out of town until Jan 3, would it be ok to drive it off and on between now and then? Any clues what the problem is?
Thanks for any help!
1. I would start by replacing the oil pressure switch. They are around $10 and it only takes a few minutes to replace.
2. Run to a local parts store and purchase an analog oil press gauge.
I would try changing the oil and oil filter. I saw something similar once with my dads '67 Ford car with a 289, forerunner of the 302 if I'm not mistaken. This car had an oil pressure light so it was noticeable right away. The car was stopped right away when the light came on after about a 10 mile drive. I started it the next day, oil light was off, drove about 8 miles oil light came on, stopped car, changed oil filter and light was off. Drove another 2 miles home, changed oil and filter. No more problem after that. Yhoa the oil filters are supposed to have a bypass, but what can you expect from a 4 dollar oil filter. Hope you get by as lucky.
on
