T19 to BW1356 Intermediate Case
Well, I got dealt another blow today. I've been in work on changing out the clutch. Took everything out, shafts, Tcase, Trans, Bell housing, clutch, flywheel. I'm going back together, replaced the rear main seal, pilot bearing, resurfaced the plate and reinstalled. Installed the clutch.
I inspected the bell housing and found 2 of the transmission mount holes cobbled. I took it to the machine shop for vatting and inserts. Today I’m working the tranny, cleaning 23 years of crud off it and remove the intermediate case from the back and one of the corners breaks right off. I guess whoever put it on there last over torque it. So, I search around the internet, 250 clams,, ouch!!!! Here's a pic of the replacement.
Yessir Russo,,, Things are coming together and it will indeed be even better then it was. Got my vatted bellhousing today, new inserts and cleaned. New intermediate case on the way.
It's just amazing the things that can be found upon disassembly of a 23 yo vehicle. I guess I could left it alone and drove it. The clutch was working fine, just throw out bearing noise. But, I just didn't feel right about it and wanted to pull it apart and make sure before I took it on a long trip, or got into a rock garden. Now I'm really glad I did.
I can put it in first without coming to a full stop so it's synchro'd, so its a 19. Mines is a 300 6 so evidently it came behind other engines then just the diesel in 88.
I hung it today (with a friends help). Rented a trans jack and lined the cradle with plywood, used and ratchet strap, cut the heads off some 5.5in bolts and installed in the top holes of the bell housing to use as guides as per the manual. Got it installed without to much difficulty. All new, improved and rebuilt forward of it. Hung the tcase as well, cleaned 23+ years of sludge off it, and resealed. I'll be dinging around, hooking it all back up over the next couple days.
Sweet.
Just because I'm curious now, what is your trans code on the door tag? And what are the last couple numbers of your vin?
Like mine is 0074 or something like that since it was the 74's off the line.
I'm just thinking maybe it was a very early "88" build and got a t19 over an m5 for whatever reason.
