Codes 54 & 67
Codes 54 & 67
So I replaced the TPS after I had to have it towed home and the TPD failed the test. It runs better than it did before, no dying going down the road. It still has a CEL on so I took it up to the O'rielly(who were very helpful this morning) and had it read. Kicked out codes 54 and 67.
54 oc ACT indicated -40�C (-40�F)/circuit open
67 o Neutral Drive Switch (NDS) circuit open; A/C or Defrost on (Manual) during test (operator error)
Having read that the Mix heat setting was on when that was tested so I can probably disregard 67.
Anyone have any experience with this particular code?
