91, F-150 Steering Wheel Play ??
Hi,
My 1991 F-150 has about 2" of steering wheel play from side to side. I took it in to a place I always deal with, and are very good and fair. They checked all front end components and said everything was fine. Ball joints, tie rods, Twin I-Beams, upper and lower control arms, etc. They adjusted the steering box and tightened the wheel bearing castle nuts. All of this considerably tightened up the steering, but I still have the play.
It isn't bad around town, but on a straight stretch of freeway at 65 MPH the thing wanders everywhere, and is a royal pain to drive. If a cop followed me for any length of time, he'd probably pull me over because he would think I've been drinking.
I called them back and they told me because of the trucks age a new steering box would not be avaliable. Only a remanufactured one, or else they could remanufactured it. The problem is they can't guarantee that would remove the play. I could spend the money, (which they said would be "pricey"), and still have the same problem. I appreciate their honesty, but I don't know what to do at this point? The truck is flawless, and in great shape except for this, so I want to get it fixed, but don't know how to proceed from here? I can't imagine this to be so difficult to pinpoint? Anyone else ever have this problem? Thanks in advance, Mel
on
That shop sounds dangerously dumb. These trucks are arguably the most-common vehicle in N.America, and the steering box is available from any local parts store, and many online sources. Read this caption:
Changing it isn't difficult, but the box is VERY heavy, and it takes a special tool to remove the pitman arm. Before reconnecting the intermediate steering shaft, make sure the box is centered. Don't allow the steering wheel to spin while the shaft is disconnected.
a couple months ago i got a reman steering box for my 92 at advance auto. im thinking it was under $200 after giving them my core. i even rented the pitman arm puller there. i dont consider that expensive, when i paid $100 for a used one 20 years ago. be sure to flush lines and pump when you do it. oh, mine is a 4x4, just realized yours isnt if you have castle nuts, but surely you can find a box anyway.
I'm looking for a solution here, and the replacing the steering box may not solve this issue. Mel.
I measured the thickness of the shim I needed to take up all the play inside the coupling at .046. Exactly the thickness of 2, 1/2" wide hose clamps. I cut 2 pieces and tapped them into place while wiggling the coupling up and down, leaving just enough of the 2 shims sticking out so that I could hold them in place with another hose clamp tightened around the lower shaft coming out of the steering box.
It worked perfectly, and there is zero play in the wheel. It's tighter than a virgin on prom night!
My repair, while a bit unorthodox, worked well as the wheel has zero play. If any play returns I could simply drill a hole through both shafts and tap a roll pin into it.
If you look at this diagram, it's at the bottom of the center series of shafts. #3E629 appear to be the clips, (shims), that are missing.
http://www.supermotors.net/registry/media/72385
True to a point. However my current repair, or a small roll pin for that matter, would give with any kind of force applied to it. That is the basic concept of shear pins on outboard motor propellers. They amount to nothing more than cotter pins or roll pins that transfer power, but break if any direct shock is applied to them.
