Canister purge solenoid cycling open/close at engine RPM speed?!
Old 09-17-2011, 09:51 PM
R.J.'s Avatar
I was listening for a tick under my hood and I happen to touch my new canister purge solenoid (old one did nothing when 12v was applied). It was my tick!! It was constantly cycling and would get faster if I revved the engine. Any ideas? The truck is a 1995 F-150 4.9L 5 Speed 2wd. Thanks
Old 09-18-2011, 06:19 PM
Steve83's Avatar
Make sure you have the hoses connected properly. If you have them reversed, it might tick.
Old 09-18-2011, 08:24 PM
R.J.'s Avatar
I will double check the hoses tomorrow. With that being said, I take it that the normal operation of the solenoid is not a constant on/off? Its open and closed should be conditional and timed, correct?
Old 09-19-2011, 05:43 PM
Steve83's Avatar
The EEC controls it. At any time when the engine is running, it might be off, on, or pulsing at any frequency. If you put a 12V test light from one of its wires to the other, the clicks should match the light. If so, the EEC is doing it; if not, it's mechanical, probably due to reversed hoses or a damaged CANP.
Old 09-21-2011, 07:58 PM
R.J.'s Avatar
The hoses are hooked up correctly. Steve83: It is normal for the EEC to make it pulse under certain conditions?
Quick Reply: Canister purge solenoid cycling open/close at engine RPM speed?!
