92 F-150 seems to have low oil pressure?
Old 09-16-2011, 04:36 PM
Woody 92's Avatar
My 92 F-150 seems to run at a pretty low oil pressure. It has the 351 in it and the gauge hangs out around the N in nornal. Is that okay?
Old 09-16-2011, 07:52 PM
losthillbilly73's Avatar
if your worried about it get a oil pressure gauge that mesures in psi not normal and i believe you should be at 40psi at idle i could be wrong but im prettysure its 40psi.
gauges are cheap you can get them at any autparts store easy to install and cheap insurance insteat of electrical that can short out youll have a mechanical hookup
Old 09-16-2011, 08:26 PM
Woody 92's Avatar
I'll do that. Thanks
Old 09-16-2011, 08:33 PM
glc is offline
I doubt that you will have 40 psi at a warm idle on an old 4.9 - I'd be happy with 15, and 40 at cruising speed.
Old 09-16-2011, 08:35 PM
he has a 351 not a 300
Old 09-16-2011, 08:47 PM
glc is offline
Okay - then 20 at idle and 50 to 60 cruising.
Old 09-16-2011, 09:24 PM
i have almost 30 at warm idle with my 300
Old 09-16-2011, 10:12 PM
glc is offline
Not shabby at all.
Old 09-16-2011, 10:19 PM
booba5185's Avatar
The gauge on a 1992 is not really a gauge, it's an idiot light with a needle. The sender is a 6 psi switch, anything over 6 psi and the gauge goes to the same spot. You can get a actual sender off of a pre-87 351(along with the elbow) then jumper(bypass) a resistor on the back of the gauges, which will make the gauge actually work. The most accurate route is to get a mechanical gauge though. Credit to Steve83 of course:
nope love me some oil pressure hahaha my 86 cutlass with a 307 only runs about 20 warm idle
Quick Reply: 92 F-150 seems to have low oil pressure?
