Best place to hook a tach into?
Old 08-31-2011, 07:36 PM
bigboy5011's Avatar
I am going to install an aftermarkt tach in my truck and dont know where the best and easiest place to intall it is...
Should I hood it to the neg coil? Crank sensor? PCM?
I tried to search the forum but no one has any real soild info...
BTW-91 f150 4.9L 5speed...
Thanks to all that help!
Old 08-31-2011, 11:19 PM
StrangeRanger's Avatar
Coil (-)
There should also be a wire from the PCM but it is just spliced to the coil (-) anyway so why bother cutting into the harness
Old 08-31-2011, 11:43 PM
losthillbilly73's Avatar
got mine hooked into the - of the coil if i remember corectly its the green with yellow stripe
Old 09-01-2011, 10:58 AM
bigboy5011's Avatar
losthillbilly-any chance you can get a pic of it for me?
I am trying to get a referene point...
Old 09-01-2011, 12:30 PM
in this one u can see both wires commin from the coil red "hot" green and yellow strip "ground"
in this one u can see i used a splice conector like what u use when hooking up a trailor harness
my tach had 4 wires red "hot" black "ground" white "light" green "to coil"
i hooked the red to the empty costant hot in my fuse block i grounded the ground to the e-break braket and i hooked the light into the dash light so when u turn the lights on the tach light comes on
in this one u can see ware i mounted my tach its out of the way but still easly seen plus it was easy to hide the wires going down into the kick pannel
also when u do this use a razor blade to cut the tape off the case on the coil wires but becarfull not to nick the wires
Old 09-01-2011, 05:36 PM
Steve83's Avatar
All the wiring needed for the tach is in the instrument cluster connectors. There's no need to pull wires thru the firewall. So the BEST place for a tach is IN THE CLUSTER - just find one in the JY and swap it in.
It's simple to open them up & swap the speedo so you keep your original odometer.
Old 09-01-2011, 05:42 PM
bigboy5011's Avatar
Thanks losthillbilly, that should work great for me!
Steve83, I got the tach as a present for my bday thats why I am just hooking this one up. Plus I like the look of an aftermarket tach! lol
Old 09-03-2011, 02:42 PM
Steve83's Avatar
You should still use the wiring in the cluster connectors to hook it up.
Old 09-03-2011, 05:08 PM
bigboy5011's Avatar
This can be done?
Which is harder? To pull the dash off and plug it in via the cluster or to just run it through the firewall into the - coil?
Old 09-03-2011, 07:48 PM
Steve83's Avatar
Depends on your definition of "harder". I'd rather sit in the seat & take out a few screws instead of lying upside-down in the floor & shoving wires through a grommet.
Old 09-03-2011, 11:21 PM
bigboy5011's Avatar
Good point...I am waiting on a chiltons but how many screws are we talking about? Even then Do I have to run any wires through the firewall? If I could just plug and go I would rather do that.
Old 09-09-2011, 05:52 PM
Steve83's Avatar
A clip each for the h/l & wiper *****, a few screws for the cluster bezel, unplug the tank & other switches (if equipped), pull 2 screws & drop the shift indicator (if equipped); 4 screws, 2 connectors, & the speedo cable, and the cluster comes out. At that point, you can either splice the tach into the cluster wiring, or just plug in a tach cluster, then put it all back in.
Quick Reply: Best place to hook a tach into?
