1987 4x4 TOD transmission info
Thanks for the replies. The sticker on the door shows trans code B.. Pretty disappointed to hear it's a weak trans. My old '90 had the M5OD, and that never gave me any problems. So far my biggest complaint about the TOD is the gear ratios! It's almost like it wasn't designed for the 300. You have to wind it out in 2nd if you want it to have any power when you hit 3rd. Otherwise it bogs right down... But anyhow, I think I'll try to get some pics of the whole works on here soon.
It's simple really.
Ball bearings = gear lube
Needle bearings = ATF
More on the T-170 series (SROD/SMOD/TOD) here:
http://www.5speeds.com/toploader.html
