springs 250 to 150
I had been wondering this also, and found out on another Ford Truck Forum that the springs for an F-250 with the diesel engine should raise the front about 1-1/2 inches or so, depending on how much sag your existing springs have. I just ordered a set for my '89 F-150 two days ago, (Moog part #CC844), I'll let you know how it turns out.
Make sure you order some adjustable camber bushings...even then you'll have a hell of a time aligning it. I suppose you could look at the bright side, before too long you'll need all new front end suspension components; so eventually it MIGHT ride better than it does now. You'll have plenty to do for awhile lol.
on
Some of us know better... They don't droop; they're BUILT that way so that, when you put a load in the back, they sit level. If he never loads it, tell him to sell it & buy a car.Tell him to leave it alone & just do good regular maintenance as described in the owner's manual.Yes, it'll screw up the alignment, ride, handling... Read these captions:
