Tensioner Pulley stubborn bolt
Re: 1994 F150, 4WD, 5.0L
How does one go about removing that doggone little bolt holding the tensioner pulley?
I need to replace the pulley; the rest of the tensioner is fine. I have to rotate the tensioner CCW as far as it will go before I can apply force to the bolt. One I get there, the bolt does not move. Is it a righty-tighty bolt, or a lefty? Should I use WD40? Do I need a giant lever arm like a long pipe over the wrench?
Thanks!
Thanks!
Thank you for the info. However, I am still confused.
Is the bolt for the pulley a lefty or a righty?
A couple of parts stores told me it's a righty, but they seemed to be guessing.
The Ford dealer said I have to replace the entire tensioner assembly. He didn't seem to know either.
I'd like to keep this a simple as possible, so I don't want to remove more parts than necessary.
I thought this would take about 10 minutes: remove a bolt, replace pulley, replace bolt, install new belt.
Thanks again!
Thanks again!
Don't have a service manual for a 94 but the manual for a 96 does not indicate that it is a LH bolt. When LH bolts are used the manual almost invariably calls them out as such. That indicates but by no means guarantees that yours is a RH bolt.
Generally for pulleys and sheaves the bolt requires an impact driver to loosen. All you'll get with a cheater bar is a sprained back or a bent cheater - or both.
It's a LEFTY!
booba5185: your comment that the bolt would loosen every time a belt was put in place convinced me to turn the bolt CW to loosen it. A little WD-40, a moderate push on the wrench, and the bolt loosened quite easily.
Thanks to everyone for your help!
But wait................There's more:
What about the little star bolt on the Idler pulley? Is it a lefty or a righty? It doesn't budge in either direction.
thanks
thanks
Looks like it is reverse thread, just like the tensioner pulley:
http://www.fullsizebronco.com/forum/...d.php?t=173154
