Was this a good transmission back in the day
The Mazdog tranny always was, is now and always will be a useless piece of junk. It is the reason that manual trannied F150s are only rated to tow 2000 lbs. The reverse ratio is so ridiculously high that you can back up at over 30 MPH but you cannot back a trailer at 2 MPH without abusing the clutch. Add to that its propensity for blowing the seal plugs out of the shift tower and peeing its load of ATF all over the highway or the extreme fragility of its shift forks and you have a worthless pile of scrap metal looking for a dumpster.
If you can get rid of one without having to pay to get it hauled away, you're money ahead. Getting someone to actually pay you for one approaches highway robbery.
Sorry you feel that way. I have seen and done some amazing things with an m5od-r2. I can agree to the shifter forks being "fragile" but it was my fault they blew. I always rested my hand on the shifter while in fourth. As for the seal plugs blowing, it can be prevented by welding metal caps in their place. At least that's what the tranny shop did when they repaired my shifter forks. That trans, after the repair, did anything I wanted it to until I sold the truck with over 400k miles! BTW it was a 97 4.6 4x4. I also own, currently, a 00 4.2 4x2 with the "mazdog" w/ 160k with no problems minus a slave cylinder. With both trucks, I have pulled over 2k lbs countless times without fail. Just my .02
