noob w/electrical problem
on
It's not the brake switch or the ICVR - neither would affect the courtesy lights. It's the terminal in the headlight switch connector; they're known to burn off, particularly on the park/courtesy/dimming power feed wire (Tn/Wh). If that's OK, it has to be in the fuse block or the wiring between the fuse & switch.
