95' F150 4X4 will not shut OFF.
Was driving home after a routine drive from work, parked my truck and attempted to turn off the vehicle. The ignition turns back as it should and I am able to remove the key..... But the truck is still running. It is not engaging somehow or feels very loose like its just spinning.
I am able to switch to the empty tank and d/c battery to save it. Also can start the truck back up no problem and drive off again.
Any suggestions? Thanks
There is a little access hole to hit the release, but I've never been able to get it. Not to hard to unscrew your tilt wheel control (if you have) and unscrew the lower column cover with three or four screws to remove. Insert key, turn to on, press small screwdriver into access hole, and slide old unit out. When you have the new switch, be sure not to turn the key back until fully inserted, or it all comes apart.
Adrianspeeder
Adrianspeeder
Provided the column is the same as a 90..
Turn the key to run, right before start position and there is a little hole on the underside of the ignition switch, push it in with a drift or a pin or something like that then pull the ignition switch out.
It's a real bugger to get the new one lined up correctly, may be easier with the wheel off.
