I got my flat bed on my custom f-250
Transmission fluid is oil, and is also red. Oil is a water repellent. Just cheep, and easy way to treat it. I can reuse what fluids I get from changing out the transmission fluids on our vehicles to treat my bed. The redness will help bring out the natural color of the red oak boards.
Well, I built the truck to be a log skidder. It also has a 5th wheel for a goose neck trailer. The bed its self is 7'6" wide, and 8' long, to carry 2 ATV's side by side.
on
Good work so far, but why half-*** the finish? The ATF will contaminate everything, leaching out over a few years, leaving the wood to degrade. ATF isn't made for wood preservation, and won't work as well as tung oil. Why not just use some cherry wood stain, and a few coats of spar polyurethane? Mix white sand with the last coat for a non-slip texture. It'll last 10x as long; it won't be a travelling oil spill; it won't smell like used ATF; and it won't turn the wood pink. It also won't degrade all the rubber it drips onto, including fuel tank O-rings, fuel lines, TIRES, mud flaps, wiring, & suspension bushings. Lastly: it won't catch fire as easily.
That was one of my jobs when i was in college doing landscaping. We had 3 GN trailers for mowers and bought a 30+ ft flat bed trailer.....he said. GO get some old oil outta the barrel and rub it on heavy....??i wasnt for sure what the reason was, but it water proofs it and actually there other trailers wood was in good order for as long as they have had them.
well as far as looks and smell go, I built this truck to be a log skidder to pull timber to my saw mill. And I added a few inches to the width of the flat bed so I can haul 2 ATV's side buy side. It took me about 7 years to collect parts, and over 3 years to build this truck. Just buying the gas to drive the truck is hard on me, being I have 4 kids and a fixed income.
Not trying to be rude, but I have had many many people disagree with much of the things I have done when building this truck. Like the 8Gal. of rhino liner. Man Oh man, have I heard the reasons not to have coated the frame and underside of the cab with that stuff, but the truck will live its life in the woods. And I am not worried about weight, or how much mud will hold on to it.
As far as the transmission fluid goes, I will not be using enough that it leaches off and harms anything on the truck, or the earth. After a few light coats, it will get a Gal or so of Thompson's Water Seal as needed.
And next year, after the oak has cupped I will sand down the edges and put 2"x2" "T" channel steal between the boards that have be coated with rhino liner for grip.
Thank you all for your input.
