I would love to get a hold of the so called mechanic who worked on my truck last.
I have been cleaning up an oil covered engine. I thought the pcv valve was puking oil, but uopn further investigation it is the passenger side valve cover. So I pulled the upper intake to give me some room and when I started to pull the valve cover I realized the bolts were barely hand tight. All of them.
Sounds like another ASE certified mechanic wasn't worth the paper his credentials were printed on. We have a few of those around here. My brother had a 78 luv mikado 4x4 and was having the engine rebuilt. He stopped by to see the progress and caught the mechanic beating in engine bearings with a ball peen hammer. He got the truck back and the motor blew again in less than 1k miles!
on
The F150 did this, and IIRC, the Bronco ones weren't exactly tight on its old engine.
on
A-ha... So you might have been a bit hasty in blaming someone for normal wear & tear on a 24-y.o. truck, huh?
I hope you're diving into all the maintenance that was skipped, like coolant, brake fluid, door seal & hinge lube, filters...
...and all the OTHER wear-&-tear items, like hoses, belts, vacuum lines, bulbs, leaves in the HVAC, suspension bushings...
Well the master cylinder was bad so I put a new one on there. With that I flushed out all of the old fluid. I had to put in 2 new hinge pins and bushings and they got greased when they went in.. It has a small coolant leak so when I fix that it will get new fluid and hoses. I have broken and replaced some vacuum lines. The heater core is bad and I can't feel air coming out if any vents even though I know the motor is turning. When I fix all of that I'm sure I will find leaves in the system.
Nevermind I got it. Talk about nasty. It had to have had 1/16" of stuff gummed up on it. No wonder why I wasn't getting any airflow. Now all I need is to find an a/c shop that still does r-12. I have the license to buy it, but I don't know if the gauges, adapters, and vacuum punp will be cheaper than just getting someone to do it.
