clutch and tranny rebuild
Im looking to rebuild both of them, wondering if you guys had any opinions on brand.
For the clutch, any opinions on material would be good. I was thinking OEM, I have 150k on a 21 year old truck, original clutch, and shes done a lot of towing, so how bad can the stock one be?
any opinions/stories would be great
I replaced my clutch when I bought my truck. It had 241k some on the original clutch and hydraulic system.
The clutch plate was not that bad, the guy babied this truck like no other. But the hydraulics were shot.
I would suggest replacing everything clutch related, except the master cylinder if it isn't bad I didn't go for that but you haaaave to replace the line from master to slave.
I used all oem parts and that is all you need unless you are making a bunch of power.
Also some specs on your truck would help for suggesting parts. 1989 f150... engines trans n so on.
Good luck to ya.
Good luck to ya.
on
You just about can't go wrong with MotorCraft parts, and yes: a new Ford clutch costs more than something from the zone, but it'll probably last LONGER than the original since it's built with newer materials & technology.
For the trans, buy a quality name-brand kit from NAPA, CarQuest, Parts+Plus, or a local transmission shop. Which transmission do you have?
on
Hey guys dont mean to interrupt but Im doin the same with my 1979 F150 Custom 4x4 4 speed, dont know what the transmisson is. Im needing a manual on how to do the transmission. I found a book (http://www.amazon.com/gp/product/156...=AYEMVW94ZBR3T) but it says automatic repair is it the same? Also i need a engine over haul manual and just a regular 79 F150 manual? Little help please? I appreciate it!!
on
Converting my '94 CV to use a '00 engine/trans/harness & '99 PCM was about a 5. But I think an old cast-iron box like that should be pretty low for you. It'll probably be pretty similar to an NP435 (which I also have NOT rebuilt yet, but I have 3 waiting), and with some Googling, you should be able to find instructions like this:
It's already there - you just have to READ THE CAPTION of that diagram in my previous post, and follow the links in it.
