New Noise
New Noise
My 95 just suddenly developed a noise coming from the drivers side front of the 5.0L engine. Sounds like rushing air and varies with rpm (and it's pretty loud!). At first I thought it was an alternator bearing but it got worse...then stayed that way. the engine is running fine...no diagnostic codes, No overheating pulleys, etc.
Could this be coming from the A.I.R system (or whatever they call it on a ford truck...)? The noise does seem loudest by the "soup can" (which I'm guessing is a muffler of sorts)
Thanks in advance,
Rick C.
Thanks in advance,
Rick C.
on
If it's coming from the metal can, that's a vacuum reservoir, so you have a vacuum leak, which should raise the idle & set lean codes and thermactor codes.
If it's coming from the plastic one, that's an intake filter for the thermactor pump. If it's coming from the pump (mounted to the engine), find out if it's on the intake or outlet side.
If it's on the outlet (blowing), you should inspect the check valves & bypass/diverter valve for damage. If it's on the intake or at the filter, check the engine mounts.
Awesome...good info..thank you much. doubt if it's the vac reservoir...no lean codes. I'm going to pull the serpentine and check all bearings tomorrow morning...just in case it's an idler or something...really sounds like air moving more than a metal grinding but I want to eliminate every possiblilty before I spend money.
Thanks again!
Rick C.
Thanks again!
Rick C.
Thanks again Steve...turns out it was the wisest! I pulled the serp..only to find a bad tensioner bearing (funny...it was only two years young?) While at it, I had a new smog pump I bought in 04 (little runnout in the pully of the old one at idle) Well the old one never quit but I wasn't going to change the serpentine without doing that job. Cleaned the air filter for it too (nasty...might be why I thought I had an air rushing sound!) The rear alt bearing was noisy too so I changed that one and put in new brushes, and finally the idler above the PS pump was noisy so I repacked that bearing and the bearing in the idler by the alt (not noisy but what the heck...I'm there anyway right) so...result...excellent and quiet...
Much abliged for your input...
Rick
Rick
on
A) The main con is that it's illegal (everywhere - not just where there's emissions testing), so discussing removing or disabling emissions systems is against the user agreement on this forum (& most others). Another con is that it's a lot of work & expense for NO benefit - the engine runs better WITH the emissions systems working. Read this article. There is no pro - the weight is negligible, and you can't use the space for anything else.
B) Why would you even consider removing the pump just because the pulley wiggles a little? Let it. It's not hurting anything. And if it gets worse, tighten the bolts or replace the pulley. Even if the pump seizes, it's easy & free to repair it.
ok ok ok I get it Steve. BTW did I mention I'm running 5% tint on the rear window of my truck???? Oops shouldn't say that. might be illegal in some jurisdictions. My inquiry wasn't intended to break any rules. it was a question. now i admit a post of mine earlier was a little out of line. but please don't follow me around the site and make me feel every question I ask about MY truck is going to violate some sort of forum rule. quit being the red and blues in my rear view!
