ignition will not turn
i tried to start my truck this morning and the ignition would not turn. it is a 1990 xlt lariat 5 speed 5.0L. the key is in all the way and it just will not turn. prior to this it had resistance and didnt turn very easily but i was going to deal with it for the mean time. the key release button seems to be where it needs to so im not really sure why it wouldnt turn
on
Are you sure it's the right key? (Yes, I've seen that happen before.) As glc suggested, if the steering wheel is hard against the lock, the key can't pull the lock out. So look at the front tires & try turning the wheel TOWARD the obstruction to take the load off the lock, then turn the key while holding the wheel.
thanks it is tilt wheel so it is probably the actuator. and yes ive tried turning the steering wheel. sometimes the ignition will turn and sometimes it will not. but as of right now i can get it to break free everytime, but not without tearing up my hands. so i will most likely replace the actuator to start with. thank you for the help
