Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 12-07-2010, 02:01 AM
1992 Ford F-150
Vehicle: 1992 Ford F150
Bilstein 5100 adjustable shocks
want to get these adjustable shocks to adjust my front end and make it level. heard nothing but good things about these. but cant find a thread for my kind of truck, 92 f150 4x2. so any one running these on a truck like or similiar to mine? if so, did you replace the stock coils?
Old 12-07-2010, 12:05 PM
Garage is empty, add now
Vehicle: 1990 Ford F150
Never heard of anyone using them on a pre 97.
They would probably do the same as a leveling kit causing bad angles for the ttb and alignment issues.
This subject has been gone over a lot just look back through a few threads and you'll see the problems.
1990 F150XLTLariat. 300I6. M5OD. HURST! 3.55LS.
BDS six inch long arm lift. 36x16.5x15 Kevlar fun country.
Old 12-07-2010, 01:33 PM
1992 Ford F-150
yeah i found that out. is your truck 4x4 or 4x2? and what kind of leveling kit did you use?
Old 12-07-2010, 02:59 PM
Mine is 4x4 and is still stock.
I'm going to skip the whole leveling kit and it's problems and just save for a lift.
There is a member, chris something or another, that used a level kit and got his aligned and it looks really good.
Old 12-07-2010, 04:09 PM
1992 Ford F-150
I've seen a lot of people run 33's on their stock 4x4, which are 2 inches higher than 4x2. So I'm sure they would fit on a leveled 4x2 right?
Old 12-07-2010, 04:23 PM
1989 Ford F-150
It'll be close, but you'll need to literally get a lift, a leveling kit will not align correctly. You will need drop down brackets and such, which come in lift kits. Without it, it'll drive\ride\steer like crap. On top of that, it'll eat tires for breakfast with a side of wheel bearings.
Old 12-07-2010, 05:02 PM
1992 Ford F-150
Buddy of mine did the samething I want, on a 95 f150 2wd and got it aligned just fine. He put 32x1150x15 and it looked good. Would that be a better setup?
Old 12-07-2010, 05:20 PM
Vehicle: 2011 Ford F150
The 5100's for the older F150's/Broncos aren't adjustable.The adjustable 5100's for the newer trucks are coilover shocks.FWIW I have the non adjustable 5100's on my 92 Bronco.
2011 FX4
92 Bronco
Got Boost?
Old 12-07-2010, 06:10 PM
Probably wouldn't fit 33's on a 2wd without a full lift. A level just doesn't get get it up there enough.
I know 33's would fit a stock 4by but i wouldn't try it.
If your buddy did it and it worked and you think it will work for you then by all means do what you want, your truck not mine.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
