speedometer jumps
I don't see how a short would do ANYTHING to this type of speedometer. There's NO, again NO electronics involved. Well, the light bulbs are pretty close, still do nothing. There is a cable (mechanical cable, not electric cable) that has a square shaped end that fits into the back of the speedometer. When the speedometer is out you can even turn it by hand and the needle will move. Where's the electronics in that? Nowhere. The cable that I mentioned goes from the speedometer to the transmission, it goes into the transmission, where it's turned by a gear. No electronics.
Since there are literally only 3 things invloved, the speedometer, the cable, and the gear, repair shouldn't be all that bad. Checking the gear is relatively easy, and cleaning the cable is somewhat easy too. When\If you need to get a new speedometer, make sure the donor truck's drivetrain matches yours. I upgraded mine from a 5.8l (mine is a 5.0) and the speedometer is off a little, my guess is the donor truck had different gears than my truck.
on
I figured it would be something like that... PUT IT IN YOUR SIGNATURE so it always shows with every post. You can omit 19xx and Ford F150 - we assume that. Put the engine, trans, 2/4WD, trim level, miles, mods, damage, repairs... Things that are specific to YOUR truck and have some bearing on questions you'll be asking here.
Then read this whole caption & the links in it:
Actually, I was trying to give him a subtle hint to create a signature by posting info about an '81.No, that's a cable-drive, too. '92 was the first year for an electronic speedo, as that caption details.
