Plowing with '94 F150 Shortbox
on
The "G" in GAWR means gross, which is all the factory weight plus fluids plus occupants plus cargo plus accessories. Read your owner's manual to calculate how much you can safely add to your front end. Also, a little further down the door sticker, you'll find the reserve capacity of the front axle:
And 600# in the bed would be a good start, but I'd aim for more. Bags of sand/gravel are good to have if you're out plowing.
I plan on doing only my own property -- not commercially. Maybe once in a while helping out a neighbor. We don't get a lot of snow around here -- around 3+ feet for the entire season. What I want to use it for is when ice forms on top of snow, which seems to happen more frequently these days. Tough to use a snow blower on wet, ice covered accumulation. I'll put around 600lbs in the back and see what happens. Keep the advice coming though. Thanks so far!
Auto with overdrive is the trans, with a 3.31 axle. The numbers/code on the sticker where the front axle accessory capacity (#24 on the above sample sticker) is F0076 and the total accessory reserve capacity (#25 on the above sample sticker) is T0422. Been doing a web serach for those codes and what they mean, but have come up empty.
on
There are at least 4 possible ODs. Use the code on your sticker & the caption of that diagram to ID your particular model of trans.Those are the weights in pounds, as your owner's manual describes: 76# front, 422# total. IOW, you shouldn't leave the plow on the truck any longer than necessary.
