Truck won't turn over, please help!
This morning, i drove my 1994 f150 to school, and it was running perfectly. After school got out, i put my key in the ignition, and tried to start it. It turned over for about 2 seconds then shut off completely. Now the starter just clicks whenver i turn the key. The truck is currently in the parking lot and I'm going to go over there later to try and fix it. Is there a way to start it? Or am i going to have to tow it and buy a new starter? Thanks in advance!
P.s. my check engine light turns on when the power is on. Also, the radio turns on and we tried to jump it with no luck.
We moved the cables around and cleaned off the terminals also, but its worth another try. Any other suggestions?
I was once told that if the battery dropped below 9 volts under load that a safety within the computer would activate and the vehicle would not start, even with a jump. IF you have a 6 with a manual tranny, it may start if pushed a few feet. Otherwise, I suggest a battery test at the very least.
on
Do the headlights go dim during this CLICK? If so, the battery terminals are the prime suspects. Read these captions:
If not; do the CEL & alternator lights come on with the key in RUN, and stay on during the CLICK? If so, the starter relay is the prime suspect, but the starter solenoid is another possibility. Turn the key to RUN and use a key or screwdriver to bridge across the 2 large studs on the starter relay.
The engine should crank, fire, & run. If you still only get a CLICK from down low beside the engine, the starter or its solenoid are suspect.
No, that's BS. Every time the key cycles to RUN, the PCM re-initializes. If there's enough juice to spin the engine, it'll try to start.
