Quote:
Originally Posted by RugerShooter
1991 F250, dual tanks.
What engine/trans? How many miles? What maintenance/repairs/modifications? How long has this symptom existed?
...the fuel pump does kick on.
Does it turn off?
(14) NO PIP RPM
(35) EFP/PFE High
(41) No EGO Switch
What do these codes mean...?
You posted the definitions (or at least PART of each definition). 14 says the EEC isn't receiving any CMP(PIP) signal from the ICM. 35 is a signal out-of-range, but it might be caused by a vacuum leak. 41 says the oxygen sensor is fouled, or the engine is running very rich, or there's an exhaust leak. If you look up those codes on another list (or a FEW others), you'll probably get some more-specific info. Try the one linked in this caption:
...could they be causing this problem.
No, codes don't cause problems - they tell you where to begin diagnosing problems.
If so what do I need to change out?
Codes don't mean to change parts. It's possible that the truck can be repaired without replacing any significant parts, so don't go on a buying spree. Read a few old threads - it almost never fixes anything.
