Engine and trans identification
Do any of you know how to tell what kind of engine and transmission are in the truck I just bought? The Chilton manual tells me one thing then contradicts it self.
The VIN # is 1FTHX25GXLKA19146
Now from what I can tell the 10 number is the year and the engine size?
This is a 1990 XLT Lariat V8 and the gearing is very low auto trans and push button over drive switch on the dash. Were are the id marks the manual said there is a tag ,I can;t find any tags?
My 1990 F-150 was destroyed by an uninsured driver. Ill send you some pictures if you want. The accident was horrific. This guy was driving a Nissan maxima with the windows rolled up the temp was 115 and passed out. Hit me head on and destroyed my truck. He hit me so hard that he knocked me into the next lane and a 03 Tahoe hit me on the passenger side. I walked away with out a scratch.
Thanks,
Unbreakable Brian
Thanks,
Unbreakable Brian
Engine and transmission identification
This is a 1990 F-250 XLT Lariat V8 automatic and the gearing is very low there is a push button over drive switch on the dash.
Thanks,
Unbreakable Brian
Thanks,
Unbreakable Brian
That vin crosses to a 1990 F-250 with a 460 V8.
https://www.fleet.ford.com/maintenan...ls/default.asp
Now, to determine trans and axle, we need the trans and axle codes off the door jamb sticker. They cannot be determined by vin. I'm 99% sure that if it has overdrive, the tranny is a E4OD. The door jamb trans code for a E4OD is "E". The axle code will be 2 numbers or a letter and a number. The letter and number combination indicates limited slip. The second character indicates ratio and has to be looked up. Example - "19" is a 3.55, "H9" is a 3.55 LS.
He has another thread goin glc, - case you didn't see it. -
https://www.f150online.com/forums/pr...ification.html
User has double posted. He has another thread going here -
https://www.f150online.com/forums/v8...ification.html
