Quote:
Originally Posted by vettekid12
im going to get a high torque starter soon for it and wrap it in a blanket.
A metal heat shield is MUCH better, but it doesn't need either. Nor does it need a high-torque starter. A normal direct-replacement is enough, IF it's a good brand. Not zone garbage.
and i want to get rid of the whole starter sloenoid on the firewall crap...
It's a relay; not a solenoid. And there's nothing wrong with it - it's a good system. You're just buying crappy parts.
and y would i change over to a new battery after i have had good luck with optimas...
Because it's only luck. It's gonna wear out. Good batteries are cheaper, stronger, last longer, and have the SAME or better warranty than Optimas (or any AGM).
But it's your truck - do what you want.
