Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 09-06-2010, 04:09 PM
Garage is empty, add now
Vehicle: 1986 Ford F150
Send a message via MSN to driver3901
I have a 300 6 in...
my 86 f150 and the distributer isn't turning. In a V8 it's usually a timing chain is it the same in a 6 cylinder?
Old 09-06-2010, 04:59 PM
1983 Ford Bronco
Vehicle: 1983 Ford Bronco
No, the 4.9L uses direct gear drive. The big cam gear usually has a phenolic (plastic) hub to reduce noise, and it can break. But if it does, it indicates some other problem -the plastic gear is very robust & plenty strong, so something had to cause it to break.
Click the image to open in full size.
Or it might be the shear pin in the distributor shaft that attaches the distributor drive gear. That breaks when the distributor bearings lock up due to poor oiling.
Walk softly & carry a BIG SIX ! ! !
Old 09-06-2010, 05:10 PM
Is there an easy way to find out if it is the pin or a gear?
Old 09-06-2010, 05:30 PM
glc glc is offline
Vehicle: 2003 Ford F150
Remove the distributor.
2003 F-150 XL RCSB 2wd 4.2 M5OD 3.55 LS
Old 09-06-2010, 05:49 PM
Could it be anything else?
Old 09-07-2010, 01:38 AM
1983 Ford Bronco
Sure. Gremlins. An alien plot. A hole in the space-time continuum...
Old 09-07-2010, 01:40 PM
glc glc is offline
How do you expect to troubleshoot distributor drive issues without removing it? There's no magical way to see what's going on any other way.
Old 09-08-2010, 12:42 PM
I pulled the distributer and there doesn't seem to be anything wrong with it. The gear turns the rotor and the pin is still there. Any other suggestions? Maybe without sarcasm. I am new to this kinda thing.
Old 09-08-2010, 01:12 PM
1996 Ford F-150
Vehicle: 1996 Ford F150
There's a limited number of things in the dizzy drive system:
The crank drives the crank gear.
The crank gear drives the cam gear.
The cam gear drives the cam
The cam drives the dizzy.
The phenolic cam gear is a known weak point, especially if you have done any upgrades to the cam or valvetrain.
When the dizzy was in place and you cranked the engine, did you get oil pressure or not? I would assume not but if you did then the problem is in the rotor connection to the shaft.
Are you capable of removing the timing, valve and lifter galley covers, removing the valvetrain and pulling the camshaft, replacing the gears and re-assembling the whole mess? If you're not, the next step may be to take it to a mechanic you trust. If you can do the teardown, start with the damper pulley and timing cover and see what the gears look like.
1996 F-150 XLT, reg. cab 6.5' box, 4.9 I6. E4OD w/ B&M alum sump, auxiliary cooler and external filter, Addco 1" sway-bars F&R, Bilstein shocks, 16 x 8 AR Bajas w/255/70-16s, Line-X spray in liner, hinged tonneau, Reese hitch and electric brake controller, VDO tranny and engine oil temp gages, stainless pushbar, Hella 550 fog and driving lights, Hella backup/work lights, 3.73 Trac-Lok w/ an alum. diff. cover with cap support screws, PFC "Z" brake pads, high flow cat with a 2.5" cat back with a FM 70 muffler.
Old 09-08-2010, 07:39 PM
1983 Ford Bronco
You don't have to take anything else apart yet. Just have an assistant bump the starter while you look down the dist. hole with a flashlight. If the camshaft doesn't turn...
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
