Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 08-21-2010, 04:01 PM
Jez Jez is offline
Garage is empty, add now
Vehicle: 1994 FORD F150
Question 94 Tire Size
Hey Guys
New to this site and new to Ford Trucks. I have a 94 F150 5.8 Reg Cab with the E4OD. Going to need new tires at some point and i was wondering the pros/cons to getting a larger size. The truck is not my daily driver, I use it for towing my boat. I want to have good wet/snow traction.
Click the image to open in full size.
Old 08-21-2010, 06:37 PM
1996 Ford F-150
Vehicle: 1996 Ford F150
What rear end ratio do you have?
It matters as to which tires you can use
1996 F-150 XLT, reg. cab 6.5' box, 4.9 I6. E4OD w/ B&M alum sump, auxiliary cooler and external filter, Addco 1" sway-bars F&R, Bilstein shocks, 16 x 8 AR Bajas w/255/70-16s, Line-X spray in liner, hinged tonneau, Reese hitch and electric brake controller, VDO tranny and engine oil temp gages, stainless pushbar, Hella 550 fog and driving lights, Hella backup/work lights, 3.73 Trac-Lok w/ an alum. diff. cover with cap support screws, PFC "Z" brake pads, high flow cat with a 2.5" cat back with a FM 70 muffler.
Old 08-21-2010, 06:51 PM
Jez Jez is offline
The Axel code is 18. I believe that's 3.08
Old 08-21-2010, 07:14 PM
1996 Ford F-150
18 is a 3.08 and taller tires will reduce your towing and your performance. You're basically undergeared already, they'll just make it worse.
Old 08-21-2010, 09:31 PM
1983 Ford Bronco
Vehicle: 1983 Ford Bronco
I run 33" tires with 3.08s, a 4.9L, an NP435 (no OD), and a heavier truck, and it works fine for me, all the way up to ~110mph.
But I don't recommend 33s for towing - the sidewall is too big to control a trailer. There's nothing wrong with the stock tire size, and it's probably the best for towing. Bigger tires don't help on-road in snow or rain. Good tires can, so buy high-quality stock-size all-weather tires. Something like BFG AT TA KO, or Michelin LTX AT.
Walk softly & carry a BIG SIX ! ! !
Old 08-21-2010, 09:37 PM
Jez Jez is offline
Thanks. Sounds like i should stick with the stock tire size.
Old 08-22-2010, 01:08 PM
1989 Ford F-150
I've been running 255/70-15s for years. Truck originally came with General Ameriways 235-75. They were hard as rocks and permitted the rear end to dance whenever they hit a puddle. I dumped them after about a year & went to Dunlop GT Qualifiers. Those are rated to carry the exact same weight as the Generals, but at a much lower psi. The 70 series adds a bit more flex and the 20mm of extra width is welcomed.
I now have 160K on it and put its 5th set of tires on in 2008.
That truck has been in every kind of weather, from years in south Texas and even a few in western NY state. The tires have not been an issue. It's just a street truck, not a 4x4 woodland wanderer.
Learn to read the tire sidewall. You'll want a good all-season tire with high numbers in treadwear and traction.
Old 08-22-2010, 11:39 PM
1983 Ford Bronco
70 isn't a series; it's the nominal aspect ratio of the sidewall to the tread width. So the original sidewalls were 235mm x 0.75 = 176.25mm tall, and the new ones are 255mm x 0.70 = 178.5mm, so somewhere around 2.25mm taller than the old ones. That's not enough to notice on a new pickup; much less a 21-year-old. But the width WOULD be appreciable.
Old 08-23-2010, 05:38 PM
1989 Ford F-150
That's where you're wrong, Steve83.
Do a google of 70 series tires and among the 311,000 hits you'll find one that reads thusly:
What size do you need? The easiest way to determine size is to look on the side of your current tires. The information is also listed in the owner's manual along with alternate sizes that will work on your vehicle.
Size refers to the combination of tire width, aspect ratio and rim size.
The first number (175, 185) is a P-metric designation that refers to the width of the tire.
The second number (70, 75) is the aspect ratio and is also called series.
The third number (14, 15) refers to the diamenter of the rim.
In common, every-day American English, if one walks into a tire-selling establishment and says they need "...70 series tires..." any individual they will encounter working there will know exactly what they are talking about.
Right?
I'll be happy to play word games with you anytime you choose.
Old 08-23-2010, 07:44 PM
1983 Ford Bronco
You can find 100 million people who call a starter relay a "solenoid". That doesn't make it a solenoid. So if you want to call the aspect ratio "series", "solenoid", or "Gretchen", it won't bother me. I didn't tell you not to - I just said it's NOT a series.
Words already have meanings, no matter how many people use them incorrectly.
Old 08-23-2010, 07:48 PM
1989 Ford F-150
Are you purposely being obtuse?
Old 08-23-2010, 09:17 PM
Location: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Vehicle: 1996 Ford F-150
Send a message via Yahoo to buckdropper
"Sex is like a euchre card game if you don't have a good partner then you better have a good hand"
1996 F-150 XLT 4X4 5.0 Longbed REGULAR CAB, auto, western plow, 2007 ford five hundred awd cvt loaded limited... titanium green metallic, tan leather..
2002 rav4 4x4
Old 08-24-2010, 02:27 AM
1983 Ford Bronco
No, but I'm through trying to get my point across to you. Call it what you want.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
