clutch replacement
It depends on how bad the flywheel is. If it is scored deep or cracked then yes. Also look real good at the teeth on the ring, that might be the determining factor.
If the slave is internal you have to ask your self "do I feel lucky punk" (Clint Eastwood) or do you want to drop everything again in---oh say a week,a month,2months?
I'd change the slave if it's internal just cuz!
That is my $0.02
That is my $0.02
If you are going to the trouble to change the clutch - do everything. Disk, pressure plate, slave/throwout bearing, PROPERLY turn or replace flywheel, pilot bearing, and rear main seal (if it can be changed with just the flywheel removed). Inspect the master cylinder carefully, and if it shows any signs of leakage, change that too.
