busted clockspring
You could install a separate button for the horn, and run the wires to it. You would need to determine the wires involved by using a wiring diagram. Assuming this is a 94 F-150, I looked up a diagram. It looks like the wires will be dark blue and dark green/orange stripe leading to the clockspring. You can locate these wires under the dash where they start to run up the steering column, and cut them there. Extend them to a push button like the one pictured below from Autozone:
Click here to see on AZ site: Dorman horn button $3.99
To wire it in, see the diagram below:
Well the clock spring is simpler to do yourself... check this out...
http://www.fordtruckfanatics.com/for...d.php?p=118231
Took me about 1hr.
Good Luck
Took me about 1hr.
Good Luck
Remove the 3-way aligning harness on the new clockspring immediately before mounting the wheel over it. Do not get this out of alignment - it is set from the factory to be where it is. Do not let it spin once you remove the 3-way harness
Dean
