Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 05-29-2010, 11:08 PM
Garage is empty, add now
Vehicle: 1987 Ford F150
Heavy Rain Stall Out
1988 F150 302cc - New Plug Wires, Throttle Position Sensor, Map & O2 Sensor
In heavy rain engine will start to miss and shut down - Doesn't happen in light rain or dry times. If you mash on the accelerator it will backfire and shut down, but if you ease off on the accelerator it will keep running as you slow down to about 20mph and then it may stall out. if it stalls you can wait about 7 minutes then it will start again and run for a few more miles when it may stall again. If you try to start in less time it just spins with no firing. Some small area must be getting wet, shorting out and then drying out in 7 minutes. Any suggestions as to what area I should look at?
Thanks,
Brer
Old 05-29-2010, 11:40 PM
glc glc is offline
Vehicle: 2003 Ford F150
Replace the distributor cap and rotor.
2003 F-150 XL RCSB 2wd 4.2 M5OD 3.55 LS
Old 05-30-2010, 11:13 AM
Vehicle: 1987 Ford F-150
Quote:
If that doesn't work, your wires could be suspect if their older, also an older PIP sensor (Stator) An error code scan may divulge that, along w/ other possibilities, like an out of range MAP/or TPS. But start w/ the most likely. All of these potential causes require a certain dewpoint to be reached. Any heat reduces that to restore function, but at a reduced level, and it will eventually get worse till whatever component involved, fails completely. Sometimes observing the engine compartment in the dark wihile attempting a start will show something. You can sometimes duplicate the condition w/ a water spray must bottle, especially the plug wires or a cracked distributor cap.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
