05-20-2010, 10:15 AM
Will a tranny off of a 302 small block fit on 91 6 cylinder?
Just curious, I have a tranny im selling and the guy wants to know. Thanks in advance, and wow I havent been on here in ages since I had my f150 in 07.
05-20-2010, 10:22 AM
should be good to go,
what year of 302??
and what trans??
05-20-2010, 11:27 AM
I think it was a late 80's truck just a reg. 302. My only concern was the bellhousing and input shaft, which I beleive I remember looking the same when I had mine.
05-20-2010, 11:46 AM
1996 Ford F-150
Vehicle: 1996 Ford F150
The bellhousing pattern is the same as is the input shaft.
The flywheel is different though, it's zero imbalance. So he will need a 300 flywheel if his is shot
1996 F-150 XLT, reg. cab 6.5' box, 4.9 I6. E4OD w/ B&M alum sump, auxiliary cooler and external filter, Addco 1" sway-bars F&R, Bilstein shocks, 16 x 8 AR Bajas w/255/70-16s, Line-X spray in liner, hinged tonneau, Reese hitch and electric brake controller, VDO tranny and engine oil temp gages, stainless pushbar, Hella 550 fog and driving lights, Hella backup/work lights, 3.73 Trac-Lok w/ an alum. diff. cover with cap support screws, PFC "Z" brake pads, high flow cat with a 2.5" cat back with a FM 70 muffler.
05-20-2010, 12:44 PM
What exact trans are you selling, and what trans in in the 300 right now? Both trucks please - 4x2 or 4x4?
2003 F-150 XL RCSB 2wd 4.2 M5OD 3.55 LS
05-21-2010, 08:33 PM
Its an AOD for a 4x2 both trucks are 4x2
05-21-2010, 08:42 PM
1996 Ford F-150
I thought we were talking about a manual tranny. If it's an auto all bets are off.
You want to put a late 80s AOD behind a 91 300?
It won't work unless you replace the PCM. The 300 came with an E4OD tranny which is electronically controlled. To put in a mechanically controlled AOD, you'd need a PCM from a manual tranny truck and even then it's not going to be a straight bolt-on. Add to that the fact that a stock AOD isn't really a very good tranny and it makes even less sense. IMHO this is just not a good idea.
05-22-2010, 12:43 AM
Yup, that's a no-go. Ford never put an AOD in a 300, they went right from the C6 to the E4OD. The only F-150 engine that ever had an AOD was the 302.
05-24-2010, 02:29 PM
he didn't ask if it would work properly, he only asked if it would bolt on
05-24-2010, 05:14 PM
1996 Ford F-150
Everyone wants to be a comedian.
Don't quit your day job
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
