F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 11-04-2009, 10:17 AM
Vehicle: 2003 Ford F150
1995 f-150 4x4 differential questions
I did a search and found info for other years but didn't know if anyone know for the 95 this info.
I am going to be replacing the gasket on the differential for my dads truck and didn't know what the capacity or type was for the gear oil when i fill it back up. I know it has the fill plug and when it starts to run out it full but does any one know if three quarts will be enough or what type is recommended I read someone say only synthetic but want to be sure for I mess his beloved truck. lol
Old 11-04-2009, 01:07 PM
Vehicle: 1996 Ford F150
According to Ford, the 8.8" axle takes 5.5 pints of 80W90. There's not a lot of 80W90 out there though. I use 75W90 synthetic. If you have a Traction-Lok Ls, be sure to add 4 oz of friction modifier
Old 11-04-2009, 01:20 PM
glc glc is offline
80W90 is the recommendation across the board for 1995's. 75W90 is acceptable. Synthetic not required. Capacity is anywhere from 5.5 to 8.3 pints depending on which exact axle you have. Fill it till it spills except with a Dana 60, that one you leave 1/4 to 9/16 inch down.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 11-04-2009, 02:46 PM
The 8.8" is your rear diff. The front diff on a 4WD F150 is a D44. It takes 3.6 pints.
1996 F-150 XLT, reg. cab 6.5' box, 4.9 I6. E4OD w/ B&M alum sump, auxiliary cooler and external filter, Addco 1" sway-bars F&R, Bilstein shocks, 16 x 8 AR Bajas w/255/70-16s, Line-X spray in liner, hinged tonneau, Reese hitch and electric brake controller, VDO tranny and engine oil temp gages, stainless pushbar, Hella 550 fog and driving lights, Hella backup/work lights, 3.73 Trac-Lok w/ an alum. diff. cover with cap support screws, PFC "Z" brake pads, high flow cat with a 2.5" cat back with a FM 70 muffler.
Old 11-05-2009, 01:00 PM
glc glc is offline
How do we know for sure that it has a 8.8" Ford rear?
Old 11-05-2009, 03:10 PM
What else is going to be in the back of a 1995 F150?
Old 11-05-2009, 08:54 PM
glc glc is offline
The charts that I use show both the 8.8 and 9 inch Ford, and a few Danas. You may very well be right, but it's possible it doesn't have a 8.8.
Old 11-05-2009, 09:35 PM
No 9" on a 95. They'd been out of production for a decade or more by then.
Danas in the rear are only used in the F250 and up
Old 11-05-2009, 10:55 PM
Vehicle: 2005 Ford F-150 4x4
Send a message via AIM to GTRider245
Agreed. Nothing but an 8.8 in a 95' half ton.
Old 11-06-2009, 12:39 PM
Thanks guys for the responses. I just picked up a gallon of amsoil 80w90 and the gasket. ready for the change
admin can close this tread if needed.
Old Yesterday, 05:57 AM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Quote:
Nope, wouldn't even be possible to run a 9" after '87 for the requirement of the tone ring and speed sensor for RABS/cruse/PSOM uses.
I'm pretty sure the last year for 9" was '85 and the first year of 8.8 was '83.
Adrianspeeder
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
