Picked up a 93 F-150 XL and Have a few issues?
Old 05-16-2009, 07:41 AM
jspec's Avatar
I picked up a 93 reg cab & long bed. It has a few issues 1st is the front tank fuel gage doesn't work. which is a bit of an issue. THe other issue is the Heat is stuck on. It is not blowing but you can feel heat from the vents. I also think something is wrong with the steering it seems to not have a center feel. It feels kinda twitching on the freeway. It only has 79000 miles so I figured everything would be in decent shape. Other then these 3 issues it runs good and doesn't shake on the freeway.
Old 05-16-2009, 03:14 PM
Showya's Avatar
If these were issues, may I ask why you bought the truck then? Fuel tank is probably a sending unit in the tank, may just be the switch, not there to help? HVAC switch may be bad, try to replace the switch and trouble shoot before you spend a ton money the seller wasn't going to spend.
Old 05-18-2009, 09:48 AM
jspec's Avatar
That is what I do. I buy and sell things! It was a good deal so the issues are just things to fix. The seller was the State so they sold it as is where is.
Quick Reply: Picked up a 93 F-150 XL and Have a few issues?
