4.9 cranks, but will not start
Old 05-14-2009, 10:00 PM
angliajim's Avatar
I have a 1995 F150 2wd supercab. I pulled it it to my shop to change oil and filter. I'm old school so I pulled the coil wire so it would not start until I built up pressure. Primed it 3 times put the wire back on and now nothing. I have spark, good compression, and new fuel pumps. My noids say the injectors are pulsing, have new cap, wires, plugs, rotor. My scanner shoots no codes. Help what am I missing? Thanks in advance for any answers. By the way, Plugs looked good , but were dry.
Old 05-14-2009, 11:20 PM
StrangeRanger's Avatar
Don't know what happened this time but next time DO NOT pull the coil wire. You are washing the cylinders down with gasoline, a really bad idea. Instead, disconnect the inertia fuel shutoff switch or pull the fuel pump relay.
Old 05-15-2009, 09:25 AM
2004f1505.4x4's Avatar
can you hear your fuel pumps running?
Old 05-15-2009, 10:26 AM
Steve83's Avatar
Test the coil's resistance across the primary (12V) terminals - it should be 0.3-1 Ohm. Then test from the (-) terminal to the secondary (output) - it should be 8-11.5 KOhm.
Quick Reply: 4.9 cranks, but will not start
