Eec-iv gs1
Any computer from a 1985 or 1986 302 FI with the 302 and AOD/C6 should work.
Just check the salvage yards.
Being older than a 1989 you may also be able to use one out of a standard shift also without the computer burning up. After 1989 a computer controlled transmission computer (4R70W [AODE] or E4OD) will burn up if you put it in a standard shift truck.
If you need the part number I may be able to come up with it, I would have to check my Fiche. Not sure if they had Calibration numbers in 1985 but if they did I would need it before I could look the numbers up on the Fiche.
