Power drain when tyring to start
Power drain when tyring to start - prob = bad battery
Hi folks
I have a 95 F150 4.9L (6I) and as soon as I turn the ignition to 'start' all power is drained and won't start (ie. dash lights go out) and looses all power.
I've changed the starter, solenoid and I still have the problem.
Any one got any ideas?
If/when you get it restarted check you voltage at the battery.
13.8 to 14.8 volts while running is correct.
If not you may need an alternator.
With the engine and key off you should have at least 12 volts at the battery.
When you try and start the battery voltage should not go below 10 volts.
Either of these things don't happen and you need a new battery.
I agree with the possibilty also of a bad battery cable/conection.
Battery connections are very good with clean connections and it shows 12.5v and when I try to start there is no voltage drop or any changes in voltage.
Using charger with 'start boost' there is still no change in symptoms.
i.e. ignition on... gas pump is heard, dash lights up fine... but when turn ignition to 'start' everything goes blank.
(Thanks in advance!) and Happy New Year!!!
