electronic problem on my 94!
hey guys.
im having an electronic problem here.
i came outside from the store one day and noticed my headlights and only headlights were on. like not the corner lights, tail lights, or anything else.
so i jump in and make check the switch, shes off still.
so i try jiggling the switches and ***** around and they still stay one.
so in the end, i ended up pulling one fuse at a time from under the hood until the lights went out.
it ended up being the 5th one (from the engine).
so now my problem is, that i have no highbeams, AND no horn at all.
if i put the fuse back in it all seemingly works fine, minus the lights always being on.
by the way, its a 94 XL, with the 5.8 liter!
any input on what this could be would be GREATLY appreciated, thanks!
I had a problem with the 94 I used to own. IIRC the signal lights would not work. I picked up a multi switch. I noticed that it bolted together. I took my old one apart and the grease inside was dried out and the contacts were corroded. I cleaned the grease out, sanded the contacts, and replaced the grease and it worked fine. Saved me about $75. It might be worth a try.
subford: i tried, but that didnt help.
redtruck: i woudl try that, but is there any tests i can try before having to rip the column apart?
and adrianspeeder: i am in canada. and it looks like the lowbeams ONLY (not the corner lights or any others)
when i pull the 'flash to pass' switch back, they get brighter. but its also a BIT brighter when i actually pull the headlight switch on.
