The clicking sound you hear should be the starter relay on the passenger side inner fender, behind the battery. The fact that it's clicking means that the system is working correctly up to that point, so it's not in the steering column/ignition switch, and it's not the neutral safety switch. That doesn't leave much else. Double check your cable connections at the battery, ground, the starter relay, and at the starter. Make sure they are all tight and clean.
Webmaster:
Rice Haters Club
My F-150 Gallery
'95 Eddie Bauer F-150 SC SB / 4.9L / 5spd / 3.55 LS / K&N FIPK w/ Ram Air / JET / Crane / Taylor / Comp Cams / Edelbrock RPM / Hurst / Add-A-Leaf / Bilstein / Bridgestone Dueler A/T Revo 31x10.5R15's / Auto Meter Sport Comp Vac, Volt, Water, Oil & Fuel PSI / K.C. / Optima Yellow / Alpine / Apple / Toshiba / Boston Acoustics / Polk / Bazooka / And more...
