Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 08-16-2008, 10:08 PM
Vehicle: 1993 ford f150 xlt
slight acceleration issue
alright, i was driving my 93 f150 5.0 auto to subway on a 35mph road. i was behind someone doing the same speed as me but then i noticed whenever i let off the throttle my truck would still start to gain speed until i slowed down and snapped the throttle real quick. this is the third time this has happened this year. when i bought the truck the throttle would sometimes stick so i sprayed thrust on it. it fixed it for the time i dont know if i need to spray it again. i changed my iac and tps in january when i did my motor. i cleaned the tb and iac and all the ports and etc. last week. do you guys think its the throttle sticking again?
Old 08-17-2008, 09:29 PM
Mass air or speed density?
If SD, then you could have a vacuum leak. A vacuum leak with SD is like opening the throttle.
Old 08-17-2008, 11:17 PM
sd. i dont here any vacuum leak but i'll check it out tomorrow. but every time its happened, i happened to let off the throttle slowly or i was barely touching it from the get go. and wouldnt a vacuum leak do it all the time instead of being intermittent? and everytime its done it, all i did was snap the throttle and its like normal again.
Old 08-18-2008, 07:56 PM
no vacuum leak, no intake leak, no leak what so ever. i just sprayed more thrust on it again and i'll just see what happens. if it happens again i'll ask again. but thanks for now.
Old 08-31-2008, 07:03 AM
Vehicle: 1987 Ford F-150
Start by cleaning any & all pivot & Friction points of moving parts and up into both ends of the cable housing where the wire enters, with someone repeatedly operating the throttle's full range of motion w/a non residue spray cleaner (like Contact cleaner or the grease won't adhere). Then spray some white lithium grease (yep, u can get it in spray form) into the workings,every movement joint of throttle spring return Mechanisms also up into both ends of the cable housing. Also, watch for binding w/ the Cruise Control cable (clean & lub it too). Do you have Cruise Control?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
