Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 08-04-2008, 04:07 PM
Vehicle: 1991 ford f150
fuel pump turns on when battery connected
hey everyone i was just wondering if when you conect the battery if the fuel pump is supposed to kick in thought it was weird so i put in a new relay but it is still kicking on for a sec or two when i connect the battery terminals to the battery
Old 08-04-2008, 06:40 PM
Vehicle: 1995 ford f150
if its the same noise as when you turn the key to the on position thats the fuel pump priming
95 f150 ext. cab
5.0 v8
SI/SO flowmaster super 40
2 12" kicker cvr's
1 800 watt rms monoblock amp(blown)
new amp- hifonics bxi1206d
6.5" infinity reference up front
6x8" pioneer 3 ways back
saving for a new truck
Old 08-05-2008, 05:10 PM
Vehicle: 1995 FORD F150
Quote:
Try turning the key off.
If the key was off your PCM Power relay or Ignition switch is bad.
Old 08-05-2008, 05:48 PM
Question
the key was off and the key was out of the ignition where is the pcm power relay located i would think that would be the easiest and cheapest thing to try first
couldnt find pcm relay but found eec power relay thought id replace it but the only place i could find the relay is at the dealer but its a $30 relay could it be the eec power relay?
Old 08-05-2008, 08:25 PM
The eec power relay and the pcm power relay is the same thing (item).
They changed names when the computer started controlling the transmission also.
I would think a 1991 would have the pcm and not the eec.
Old 08-05-2008, 08:31 PM
i thought they were the same just wanted to know for sure but under the hood the only relays that my 91 has is fuel pump and eec power
Old 08-05-2008, 08:37 PM
I do not have a 1991 manual but I see the 1990 manual calls it the eec power relay and the 1993 was the first year they called it the PCM Power relay.
Old 08-11-2008, 03:19 PM
Vehicle: 10 FULLsize ole' Ford rigs
Ditch the cheezy factory style relays and buy two simple rugged 30amp bosch relays.
Pins are labled on the relays
EEC PWR
30 - Y (always 12V)
87 - Bu, DB, R (out to EEC)
85 - Wh/LB, R/LG (12V in from ig.sw.)
86 - Bk/LG, Bk (ground)
FP
30 - Y (always 12V)
87 - Pk/Bk, Br, DG/Y (out to inertia sw.)
85 - R (12V in from EEC PWR relay)
86 - T/LG, LB/Or (ground from EEC)
Adrianspeeder
Old 08-12-2008, 12:37 AM
where is a good site to look at these bosch relays?
91 f150 xlt lariat
inline six
4 speed manual
Old 08-12-2008, 01:43 AM
They are six bucks at napa.
Pigtail and relay part numbers.
Adrianspeeder
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
