Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 08-02-2008, 09:31 PM
Vehicle: 1992 Ford F150 4.9 L
Unhappy 92 f150 4.9 liter 300 6 won't start
I just installed a rebuilt engine in my pickup about 2 weeks ago and have been scratching my head ever since because it will not start. I think it has something to do with not getting any fuel, I know my pumps in both tanks are working and there is good fuel pressure all the way up to the injector fuel rail but I do not think my injectors are "pulsing". I can only access the #1 injector connector because of the huge gigantic air intake in the way. Anyway, when the engine is cranking, I can put a test light on the connector and the light lights up in both pins, but when I put a volt meter on the pins, I am not reading any voltage. I have checked all of my sensors that input into the EEC IV and the sensors test fine. Is there something screwed up internally in the EEC that is telling the computer NOT to send a good enough signal to the injectors to "pulse" ? Also, I keep on reading about a crank sensor that tells the EEC to vary the rate of puls to my injectors. I swear up and down I do not have a crank sensor so where else would I be getting the signal from? Please help
Old 08-02-2008, 10:10 PM
Vehicle: 1996 Ford F150
The crank sensor is the PIP (profile ignition pickup) in the distributor. You cannot randomly assign #1 on an EFI engine for that reason. #1 should be marked on the distributor cap andit must be that one which is connected to plug #1. None of that is likely to explain your failure to start though unless you're 180° out. are you sure that the rotor is pointing to #1 on the compression stroke?
Old 08-02-2008, 10:22 PM
Vehicle: 93 F-150 4x4 351W
Sounds like the computer is not getting power or ground. There should be a smaller ground that goes directly to the battery post - make sure that is connected (it's the ECU ground). I'm not sure how the ECU gets +12V, you may want to check that on a schematic.
Old 08-02-2008, 10:34 PM
I have checked the timing a thousand times and today 1001. I did mis speak about the power at the injector connector. I am getting 12 volts to both pins with key on and engine not cranking, I am also getting 12 volts to both pins with key on and engine cranking. I do have a schematic and I am getting 12 volts to the computer. So my question now is, when then there is 12 volts at the connector on both pins, that is not right is it? And, is the injector normally open with power or is it normally closed with power ? Thanks for the responses.
Old 08-03-2008, 12:32 PM
Vehicle: 1995 Ford F150
Voltage is always supplied to the injectors when the key is on, including cranking. The ECM sends a signal to ground them when it wants them to squirt, so to speak. I've never tried using a DMM to confirm the signal, I always use noid lights, but if your DMM responds fast enough, you should see a pulsing signal when the engine is cranking.
Have you checked for KOEO codes?
Webmaster:
Rice Haters Club
My F-150 Gallery
'95 Eddie Bauer F-150 SC SB / 4.9L / 5spd / 3.55 LS / K&N FIPK w/ Ram Air / JET / Crane / Taylor / Comp Cams / Edelbrock RPM / Hurst / Add-A-Leaf / Bilstein / Bridgestone Dueler A/T Revo 31x10.5R15's / Auto Meter Sport Comp Vac, Volt, Water, Oil & Fuel PSI / K.C. / Optima Yellow / Alpine / Apple / Toshiba / Boston Acoustics / Polk / Bazooka / And more...
Old 08-06-2008, 09:55 AM
Well, several days later I found the problem and it started right up. The 2 wires that fed the ground to start pulsing the injectors. The sheilding was melted. I suppose when I was monkeying around with the harness when installing the engine that I disturbed them enough to make em touch. I am not a good electrical guy so I feel pretty good that whatever it was works now. I sure appreciate the comments and suggestions guys, Have a good one.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
