Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 07-31-2008, 08:52 PM
Vehicle: 1996 Ford F-150 4x4
CEL on but can't get any codes!
my check engine light came on the other day while i was just driving down the road, i was running very low on gas, so i went and "filled" up (30$) some in each tank, still there, checked coolant fluid level, oil, all good, unhooked battery to clear code, came back on next day, ok.... put some good old sea foam in 'er cleaned out air flow sensor on top of intake manifold, unhooked battery again, back on next day, so i finally stuck it on the scanner, it gets half way through the self test and then quits code P1000 "self test incomplete" tried three times, and its a brand spanking new snap-on scanner so its not the scanners fault, the only problem with the truck is sometimes when i start it up it idles extremely rough and then it either stalls or runs right, anybody got any suggestions?
Old 07-31-2008, 11:11 PM
Vehicle: 1993 ford f150 xlt
what motor? you can use a carb cleaner to spray around the intake manifold gasket. possible vacuum leak or iac or fuel pressure leakdown problem and etc. when you did the test did you turn everything off as in the radio, blower motor? and does your truck have obd2 or is it the old ford 1b style? if ford 1b then did you try koeo and koer or just one or the other?
Old 08-01-2008, 09:06 AM
Quote:
4.9L, think so, obd2, first year for 'em, and both
Old 08-01-2008, 07:32 PM
Vehicle: 1995 Ford F150
Does the fuel pump ever continue to run whenever the key is on, and the engine is off?
Webmaster:
Rice Haters Club
My F-150 Gallery
'95 Eddie Bauer F-150 SC SB / 4.9L / 5spd / 3.55 LS / K&N FIPK w/ Ram Air / JET / Crane / Taylor / Comp Cams / Edelbrock RPM / Hurst / Add-A-Leaf / Bilstein / Bridgestone Dueler A/T Revo 31x10.5R15's / Auto Meter Sport Comp Vac, Volt, Water, Oil & Fuel PSI / K.C. / Optima Yellow / Alpine / Apple / Toshiba / Boston Acoustics / Polk / Bazooka / And more...
Old 08-02-2008, 02:57 PM
Vehicle: 1997 Ford F150 5.4
There's nothing wrong with the scanner.
You need to QUIT disconnecting the battery. Then, the CEL will come on when the computer fails a test and THEN hook up the scanner. Every time you disconnect the battery, it resets the computer, erases the failure code, sets a P1000 status code, and then tries to re-run all the on-board emissions monitors. Since you keep "rebooting", it isn't getting anywhere useful.
FWIW, you likely have either a vacuum leak, a flaky IAC valve, or low fuel pressure based on the operating symptoms you gave.
Steve
1989 Taurus SHO What a project!
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's daily driver
Old 08-04-2008, 12:02 AM
we unhook the battery in order to clear the code to see if what we did worked, we only scanned it when the cel came back on, so the computer should've had a code, and on friday i cleaned out mass air sensor and switched to front tank and it hasnt came back on yet. *knock on wood*
Old 08-11-2008, 07:26 AM
Update?
Webmaster:
Rice Haters Club
My F-150 Gallery
Old 08-12-2008, 11:08 PM
I cleaned the mass air flow sensor out and switched tanks and so far so good. The sensor had like to green dots on it, they came off with 2+2 though
The Crazy Redneck from Maryland
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
