Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 07-30-2008, 11:36 AM
8.8 Rear End
Hey, sorry for the noob question, but I am changing my rear end oil, and my housing has no fill plug. I assume I can fill it through the rear break sensor, but how do I know when its full? Also, how do I determine if I have limited slip?
Thanks.
Old 07-30-2008, 12:09 PM
Vehicle: 1994 Ford F150
getting ready to go to work, so i cant answer the limited slip question with any more info than this...look on the rear end housing and there should be a metal tag with all the info stamped on it....what gear ratio's, whether limited slip...etc. You can also check the drivers door sticker for the axel code and do a google search...that's what i did, but dont remember the site right off the top of my head.
As for the fill plug, mine was on the front of the axel housing (slightly up and right of the center) ...towards the engine. Just take a regular ratchet to undo it.
If no one else answers, I'll try to go into more detail on the limited slip question when i get home tonight.
mark
Old 07-30-2008, 12:44 PM
Appreciate that information, found it, and tag says no limited slip.
Thanks.
Old 07-30-2008, 01:39 PM
Vehicle: 10 FULLsize ole' Ford rigs
Door jam sticker axle code. If starts with a 1, not limited slip, if starts with a letter, usually H, limited slip.
The fill plug is upper right of the pinion and fill to that level.
Adrianspeeder
Old 08-01-2008, 09:19 AM
Vehicle: 1995 Ford F150
FYI, a quick way to tell if an axle is limited slip is to jack it up and spin one of the wheels. If the other wheel spins the same direction as the first, it's limited slip. If the other wheel spins the opposite direction, it's an open differential.
This is a real quick way to check if a differential that is supposed to be limited slip is working properly.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
