07-25-2008, 09:24 PM
1994 w/ 302 oil ???
Folks,
Sorry for the stupid question but I just bought a 94 with the 302 and it didn't have an owner's manual. What type of oil do I need and what is the capacity? Thanks!
07-25-2008, 10:34 PM
Vehicle: 1993 ford f150 xlt
recommended should be 5w30. i use 10w30 in the winter and 15w50 in the summer for the extra protection. and it should hold about 5.5 to 6 quarts.
07-26-2008, 01:24 AM
Vehicle: 1996 Ford F-150
If u really love your truck use Delo 400 its a little pricy though.
07-26-2008, 02:23 AM
Vehicle: 1995 Ford F150
The factory recommended viscosity will be on the emission decal under your hood.
Webmaster:
Rice Haters Club
My F-150 Gallery
'95 Eddie Bauer F-150 SC SB / 4.9L / 5spd / 3.55 LS / K&N FIPK w/ Ram Air / JET / Crane / Taylor / Comp Cams / Edelbrock RPM / Hurst / Add-A-Leaf / Bilstein / Bridgestone Dueler A/T Revo 31x10.5R15's / Auto Meter Sport Comp Vac, Volt, Water, Oil & Fuel PSI / K.C. / Optima Yellow / Alpine / Apple / Toshiba / Boston Acoustics / Polk / Bazooka / And more...
07-26-2008, 06:09 PM
Thanks fellas. It's a beater that I only gave a thousand for, but after a good cleaning and a throttle position sensor it's already twice the truck that it was when I bought it. It needs a little front end work (tie rods, bushings, etc), but other than that it'll do the dirty work that I don't want to commit my Expy to. Thanks again. BTW, you guys have some nice trucks!
1994 F150
2005 Eddie Bauer Expy
07-28-2008, 05:04 AM
Vehicle: 2006 Ford F-150
10w30 and a wee bit over 5 qts
recommend you use the motorcraft synthetic blend. good stuff and been using it for many years
07-29-2008, 10:15 PM
Thx Tylus!
07-30-2008, 10:44 AM
Vehicle: 1995 Ford F-150 5.0L
Quote:
Originally Posted by
Tylus
Same here.
MPG Enhanced
Pioneer-Crossfire-Yaesu-Comet-K&N-Magnum-Monkey Made
07-30-2008, 01:25 PM
Vehicle: 10 FULLsize ole' Ford rigs
Shoot, I run 20w50 in the older ones.
Adrianspeeder
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
