Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 07-15-2008, 11:33 PM
Vehicle: 1997 Ford F250 HD
Talking '97 F250 HD No Power When Hot
I recently bought a 1997 F250HD 4x4 w/5.8L. The truck has 144,000 original miles. PCM went out about 2 months after I bought truck. It went into Failure Management Mode and wouldn't clear.One code only code shown was IAT sensor.But,after replacing it,still didn't clear.Did pin test and PCM showed bad.
Well,now truck seems sluggish with new PCM.Checked timing,it's dead on 10* base,air filter is new,I did a vaccuum check to see if any backpressure problems with exhaust and everything checked out fine.
Truck seems to have power when cold,but,after reaching normal temp,it's a slug.Lugging up hills.I pulled out the new IAT as it was an Autozone unit. I put the factory IAT back in.Haven't had a chance to drive it yet with old IAT.
I do know my fuel economy has dropped from 16MPG to about 10MPG.
Also,when I leave truck idling for about 5-10 minutes,it will idle up,sputter and shut off.Turn key and it will spin over but not start up.After sitting for about 15 minutes,it will start up just fine.
Anyone have any clues? Suggestions?
Old 07-17-2008, 11:12 AM
Vehicle: 10 FULLsize ole' Ford rigs
Bad coil, and/or tfi module on the distributor.
Adrianspeeder
Old 07-20-2008, 04:29 PM
Alright,replaced IAT with a new factory Ford unit,replaced TFI with factory Ford unit also,TFI unit was factory remote mounted on drivers side fender to help reduce heat.New MSD Blaster coil,New Motorcraft Platinum plugs and Motorcraft wires.Replaced standard air filter with a new K&N unit. Only thing I haven't changed yet is the fuel filter.
Also,as far as the sputtering and stalling after idling for several minutes,I connected a spark tester to plug wire and have plenty of spark.So,I'm leaning more toward fuel system.Fuel reg issue? Any info would be greatly appreciated.
Swampfox44
There's a fine line between CLEVER..........and STUPID!!!
Old 07-20-2008, 08:11 PM
Vehicle: 2003 Ford F150
confirm fuel pressure with a pressure guage on the fuel rail.
sounds like your pump is going bad or you are vapor locking
Old 07-20-2008, 08:41 PM
Got dual tanks and does it with either tank.Any cure for vapor lock?
Old 07-26-2008, 01:43 AM
Vehicle: 1995 Ford F150
I'd change the fuel filter, and if the problem persists, check the fuel pressure when it dies and see what happens.
Webmaster:
Rice Haters Club
My F-150 Gallery
'95 Eddie Bauer F-150 SC SB / 4.9L / 5spd / 3.55 LS / K&N FIPK w/ Ram Air / JET / Crane / Taylor / Comp Cams / Edelbrock RPM / Hurst / Add-A-Leaf / Bilstein / Bridgestone Dueler A/T Revo 31x10.5R15's / Auto Meter Sport Comp Vac, Volt, Water, Oil & Fuel PSI / K.C. / Optima Yellow / Alpine / Apple / Toshiba / Boston Acoustics / Polk / Bazooka / And more...
Old 08-02-2008, 11:19 PM
Well,got fuel filter changed (still had factory one installed), also checked fuel pressure.I've got 32psi at idle,38psi at cruise speed and 40psi under load.The more I have thought about it,it doesn't have the power it had even cold since replacing the ECM. I pulled plugs as well today and they look new,no tan or carbon coloring at all , they are bright white like out the box so, I'm thinking I've got a lean-run condition. Going to try to get by dealer and have friend run a scan and see if anything shows. What's chances of the ECM bought from Ford being bad?
Swampfox44
Old 08-02-2008, 11:49 PM
Vehicle: 1993 ford f150 xlt
Quote:
somethings wrong there. your pressure should go down as your rpms go up.
32psi is borderline at idle.
Old 08-03-2008, 12:43 PM
Actually, it's the other way around. The pressure increases when the vacuum is reduced or removed from the regulator, and opening the throttle reduces manifold vacuum. Thus, when you "give it gas", you are causing the fuel pressure to rise.
Webmaster:
Rice Haters Club
My F-150 Gallery
Old 08-03-2008, 06:36 PM
Quote:
really? huh, ok well, just dont mind me. i cant think worth a damn this week.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
