Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 07-12-2008, 03:26 AM
Vehicle: 1997 Ford F250 HD
1997 F250 HD 5.8 Problem
I've got a 1997 F250 HD 4x4 w/5.8. If I leave truck idling for a few minutes after fully warmed up,it surges at idle and shuts off and will not restart for about 10 minutes. It will spin over but acts if it has no fire or either no fuel.
Also,anyone know which mark on timing tab to time engine by? Top flat area or lower indented area? Thanks
Old 07-12-2008, 07:16 PM
Vehicle: 1993 ford f150 xlt
the coil could be overheating or a distributor issue when you let the truck run. i'd check for spark first, when it shuts down put a tester on it and have someone crank it as you look for spark. if thats not an issue then check for fuel. it has nothing to do with timing or it would not start at all or would run like hell.
Old 07-12-2008, 07:22 PM
Yeah,I was thinking possible coil/dist issue as well.Was going to do a spark test.Was wondering if maybe clogged CAT? CAT is smelling really bad,truck only has 150,000 miles. Also,I recently had PCM replaced due to an issue.Was just wondering as far as the timing in general,truck seems to run a bit weaker and sluggish with the new PCM as well as the MPG has dropped drastically. With old PCM,engine had been running in failure management mode and didn't know if previous owner had messed up timing or what.
Old 07-12-2008, 07:36 PM
well you can try and cut the exhaust right before the cat to see if thats the issue. has the motor been tuned up? you could also change the fuel filter. i'd start off with the cheaper stuff before going crazy on the money.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
