Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 07-09-2008, 10:24 PM
Vacuum Hose Missing?
I haven't picked this Bronco up yet but from the pictures of the engine bay it almost looks like there is a hose missing. What do you folks think?
Look right behind the battery. Ooops. I should've mentioned it's a "95 Bronco 351.
Thanks in advance.
Old 07-09-2008, 11:06 PM
Vehicle: 1993 ford f150 xlt
thats just for the air injection pump. its suppose to be like that.
Old 07-09-2008, 11:56 PM
Vehicle: 1996 Ford Bronco
yes its where the smog pump sucks air from. Its made like that.
btw, if you take the top radiator hose and loosen the clamp to where the hose connects on the t-stat housing, turn the hose a bit and the hose will stand up and sit on top of the radiator shroud. You won't need any zip ties to hold it up.
-1996 & 1990 Ford Broncos-
Old 07-10-2008, 01:02 AM
Vehicle: 1995 Ford F150
Actually, there is a hose missing, but it's nothing to lose any sleep over. There is a paper flex hose that goes on the end that you were concerned about, and follows the fenderwell down towards the firewall. It's only purpose is to reduce the possible road debris that could get sucked into the smog pump filter.
Not critical unless you do a lot of driving on dirt/gravel roads.
Webmaster:
Rice Haters Club
My F-150 Gallery
'95 Eddie Bauer F-150 SC SB / 4.9L / 5spd / 3.55 LS / K&N FIPK w/ Ram Air / JET / Crane / Taylor / Comp Cams / Edelbrock RPM / Hurst / Add-A-Leaf / Bilstein / Bridgestone Dueler A/T Revo 31x10.5R15's / Auto Meter Sport Comp Vac, Volt, Water, Oil & Fuel PSI / K.C. / Optima Yellow / Alpine / Apple / Toshiba / Boston Acoustics / Polk / Bazooka / And more...
Old 07-10-2008, 01:03 AM
Also, FWIW, one of the first things I'd do if I were you is flush that brake fluid out, and replace it with some clean new fluid.
Webmaster:
Rice Haters Club
My F-150 Gallery
Old 07-10-2008, 02:23 AM
Thanks guys. Hopefully I'll get to pick it up tomorrow. He's asking $2500.00 with 117k miles on it. It's not perfect, but I should get a lot of miles out of it..
Thanks again.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
